Quick question, is a mk2 Chamois high or Low pivot? And if high what is the common way to get the camber correct/slight negative...
    • 8514
    Quick question, is a mk2 Chamois high or Low pivot? And if high what is the common way to get the camber correct/slight negative? Springs, modifying the stub axles or lowering the pivots? Thank you, Steve.
