Bob Pictons Washer Jet Replacements - NEW COLOUR JETS - NOT JUST FOR IMPS !
    replied
    Put together this little package today , some finished ,some not , some modified jets ,some not yet modified , also pictured two styles for boot\bonnet mounted on fibre glass , one pair being sent out for fitment to Marcos ,the other probably going on Petula​ pictured also shows two cars worth of sump\ gearbox magnetic drain plugs.
ID:	4349Click image for larger version
ID:	4350Click image for larger version
    Leave a comment:
    replied
    Note
    The single jet chrome unit has a 5mm thread , it is the only one that size, all the other types have an 8mm thread , l have stocks of single jet chrome but haven't fitted any to housings yet .
    l have just made a batch of 10 cars worth , 7 sets with 8mm thread with 3 sets left unmachined should anyone want the single chrome jet which l am now allocating as a special order.
    Also made a few of different design that will fit fibre glass boot lids (Petulas) also looking at fitting Marcos .
    Still awaiting a delivery of coloured jets
    Many thanks to John for loading this topic and all his help in my Imp related products
    Leave a comment:
    replied
    the colostomy bags didnt hold much at all
    Leave a comment:
  • Bob Pictons Washer Jet Replacements - NEW COLOUR JETS - NOT JUST FOR IMPS !
    Bob Pictons Stainless Washer Jet Replacements - NOT JUST FOR IMPS ! - Now with new spray patterns and in full colour !
    Click image for larger version  Name:	IMG_20200121_065244623_HDR.jpg Views:	0 Size:	394.7 KB ID:	3666 Click image for larger version  Name:	IMG_20200121_064005156.jpg Views:	0 Size:	494.0 KB ID:	3667
    Although primarilly made for the Imp Bobs jets can be retrofitted to almost any vehcile, even as a bonnet mount jet
    Get some for your classic Ford, MG, Avenger, (ah choo Mini even)
    For a article on fitting the washer jets please click HERE IN ARTICLES
    Below as you can see I replaced my existing "pic-jets" with some new style ones from bob to see what the difference was like.
    On Boris I already have them installed for a long time now but as a single side mounted jet. It was interesting to see how the pattern on these went as there is no vertical adjustment to speak of,
    Click image for larger version  Name:	20200201_125529.jpg Views:	0 Size:	221.1 KB ID:	3670 Click image for larger version  Name:	20200201_125527.jpg Views:	0 Size:	614.5 KB ID:	3671 Click image for larger version  Name:	20200201_125808.jpg Views:	0 Size:	304.4 KB ID:	3672
    Standard jet (single) that i selected originally
    Click image for larger version  Name:	20200201_125534.jpg Views:	0 Size:	270.2 KB ID:	3668 Click image for larger version  Name:	20200201_125812.jpg Views:	0 Size:	450.6 KB ID:	3669
    Installation process is just the same, loosen off jet holder body, get in behind the jet and O ring with metallic blunt edge (i used my credit card) as it needs a firm push to free off the clips behind, the sping material is pretty strong.
    Removal of existing jet (same process as standard one as clip is the same)
    The new jets rhemselves have a different fixing from the other ones so need a matching jet body
    Click image for larger version  Name:	20200201_125823.jpg Views:	0 Size:	436.8 KB ID:	3673 Click image for larger version  Name:	20200201_130459.jpg Views:	0 Size:	496.5 KB ID:	3674
    Click image for larger version  Name:	20200201_130425.jpg Views:	0 Size:	514.6 KB ID:	3675 Click image for larger version  Name:	20200201_130529.jpg Views:	0 Size:	310.0 KB ID:	3676
    The "goo" seen is just silicone based grease used to make threading and seating on the body easy for the O ring, when the car is washed the oyuter traces go but the inner protection has remained. Shows how well these seal from the outside in all weathers !
    Thats the new ones in
    Click image for larger version  Name:	20200201_130646.jpg Views:	0 Size:	133.6 KB ID:	3677 Click image for larger version  Name:	20200201_130648.jpg Views:	0 Size:	273.2 KB ID:	3678 Click image for larger version  Name:	20200201_130739.jpg Views:	0 Size:	562.2 KB ID:	3679
    New spray pattern on passemger jet, standard jet on left
    One comment I would make is the new jests seem to use a lot more fluid at one time, could result in less sprays needed but more likely result in a bigger washer bottle needed, the little bag inside Boris bonnett wont last long !
    Petowner Colimp66 Dave Lane
    Please contact Bob directly for any purchases bobs_washer_jets@hillmanimp.org
    Please remember and let Bob know which type of jets you would like.
