Headlamp bowl mod
    Headlamp bowl mod
    OK so its already been done on here but to keep all my mods in one place id thought id add mine as well .
    This is only needed if your running halogen headlights , makes changing a bulb a doddle with no need to remove the headlight ala. sealed beams . running halogens also means you can put the sidelights in the headlights giving a much bigger visible sidelight .
    Headlight bowls are NOT handed , its the same bowl for both sides , its just the mount its on is handed .
    Doing the Drivers side ( RHD ) headlight is easy however the passenger side is a little more complicated . just remember you MUST leave the spring tag in situ or you will get a very wobbly headlight .
    I used a 1mm thick cutting disc on a grinder - takes seconds
    Pictures tell the story better
    Drivers side
    Click image for larger version  Name:	IMG_2098.JPG Views:	0 Size:	1.04 MB ID:	3444
    Passenger side is more involved , you need to drill a mirror image wire entry hole and flare it slightly like the original , i just used a suitable socket and a hammer .
    Click image for larger version  Name:	DSCF2614.JPG Views:	0 Size:	1.46 MB ID:	3445
    Then cut the other side out that was the original cable hole
    Click image for larger version  Name:	DSCF2616.JPG Views:	0 Size:	1.08 MB ID:	3447
    Sandblast , etch prime then paint
    Click image for larger version  Name:	DSCF2620.JPG Views:	0 Size:	444.5 KB ID:	3449
    Then fit . if your fitting the sidelight in as well part of the silver mount will need removing to clear the bulb , passenger side in
    Click image for larger version  Name:	IMG_2099.JPG Views:	0 Size:	1.35 MB ID:	3450
    Drivers side , note the spring and tag which must remain however much you chop out
    Click image for larger version  Name:	IMG_2098.JPG Views:	0 Size:	1.04 MB ID:	3451
    Whilst your at it do away with the headlight earth on top the inner wing and add a dedicated earthing point for the headlight / indicators / electric washers etc ( further posts later will show you how )
    Click image for larger version  Name:	DSCF5019.JPG Views:	0 Size:	1.12 MB ID:	3452
