Has anyone successfully removed the accelerator pump discharge pipe from above the choke in a Solex carb and then replaced it? I have a feeling that the reason my car hesitates, almost to the point of stalling when I blip the throttle from idle, is some grit, or whatever, stuck in the pipe between the one way valve and the tip. Sometimes the flow is right through the choke but more often it either dribbles out or the flow goes at right angles against the side of the choke. Before I go and ruin an otherwi
    • 8396
    Has anyone successfully removed the accelerator pump discharge pipe from above the choke in a Solex carb and then replaced it? I have a feeling that the reason my car hesitates, almost to the point of stalling when I blip the throttle from idle, is some grit, or whatever, stuck in the pipe between the one way valve and the tip. Sometimes the flow is right through the choke but more often it either dribbles out or the flow goes at right angles against the side of the choke. Before I go and ruin an otherwise perfectly good carb, it would be good to have some advice. Thanks.
