This is real easy to knock up . All you need is some standard 15mm copper pipe and copper brake pipe , Kunifer pipe is too stiff so it must be the copper type .
Get your length of 15mm pipe stood up in a vice and wrap the brake pipe around as tight as possible .
Cut the ends of the brake pipe to around 2 inches long and add a slight flair and you end up with this . The longer the coil the better within reason , 5 inch is good enough .
Solder this to the 15mm pipe , just the ends and a bit in the middle will do
Cut the 15mm pipe to the required length and solder on a compression ring on both ends , this heap doesnt have a factory valve , just a plumbing screwdriver one so i used the compression gland on one end C/W nut , you wont do this .
