Period legal for motorsport disc brake conversion
    The complete kit is £1200 inc postage to UK mainland. Callipers, billet anodised brackets, billet anodised hubs, long or extra long studs, timken or SKF wheel bearings inc seals bearings can be loose or pressed in for you, stainless steel dust caps, bolts and schnorr locking washers, Mintex classic pads (or pad of any compound in mintex range), stainless steel bleed nipples. Pipes made to order in stainless steel fittings and aeroquip pipe. Full back up and instructions should you need it. I have found some stub axles to be machined at different sizes which can mean the calliper can sit in the wrong place so i have in stock shim washers i will also bespoke make the brackets should you not want shim washers or your stub axles are way out and require bracket machining more.
    If you are running Sp 12 callipers i have billet anodised brackets to suit them in stock. £60 pair delivered to UK.
ID:	13910Click image for larger version
ID:	13912Click image for larger version
ID:	13914Click image for larger version
