Hillman Imp MK 1 aka " Doris " - YNC 319A - originally 4173 FM
    Well what can we say about Doris.
    This is the car I actually want to restore but all the others managed to get in the way for the past years.
    Paul Coulter had it stashed away in a lock up in Ayrshire after picking it up in 2014 along with PKE321M (Ex Kent Police Imp) and you can see a picture here
    https://www.theimpclub.co.uk/wp-cont...ary-2016-1.pdf
    Paul is also an author and playright and loves his Imp history
    https://www.dailyrecord.co.uk/news/p...-gears-2808651
    He released this in 2013
    https://www.amazon.co.uk/Our-Hillman.../dp/1908931310
    So as you will expect, the car came with a fair amount of research on its origins.
    One thing that the DVLA would not do unfortunately was asign the initial registration to the car 4173 FM as the original owner had retained it which is why it ended up with an A plate and the current registration YNC 319A. Between Paul and The Imp Club who has a dedicated DVLA contact the muddle was sorted out.
    To rubber stamp the originality I requested a Heritage Certificate from Bob Allan at The Imp Club on behalf of the Rootes Archive Trust
    The heritage certificate (see example on link above) is simply a lookup from FACTORY records and confirms the vehicles details and when it was actually made and the series it was made in.
    From Doris certicificate as well as being confirmation that the car is actually what it is we got the following information.
    Make and Model
    Hillman Imp de Luxe Mark I
    Chassis Sequence
    B.411000001 to B.411080404 then B.419080405 onwards. Mark II de Luxe was introduced in 1965.
    Total Production
    440,032 Imps were built at Linwood. 80,404 Mark I de Luxe from the first series, other sources indicate total 98,077 including export with 7,440 in CKD form.
    Around 33,000 Imps were sold in the UK in 1963.
    Specification
    2-door saloon, home market, standard specification
    Transmission Type
    4-speed manual, all synchromesh
    Identification Numbers
    Car-chassis B.41100505X HSO; Engine: B.41100505X, 875cc, 4-cylinder ohc high compression (10:1)
    Colour
    Exterior Foam White (code 8); Interior trim: Black
    Approx. Dates
    Manufacture week ending 14/6/1963, exact day not recorded
    Registration Mark
    4137 FM registered on 1/7/1963. This mark was available in Chester from June 1962. Records maybe in the Chester office. Now YNC 319A, an age related plate issued on 13/4/1989. YNC would originally have been for the Manchester Borough area.
    Other Information
    A car like this would have cost £532 including £92-4/7 purchase tax. Parts list 6601249 or 6601476 ; Handbook 6601017 ; WSM.141 6601284
    Only deviation from factory records is the interior colour which is actually red (not black)
ID:	112Click image for larger version
ID:	115Click image for larger version
ID:	114 Click image for larger version
    And a few more pics the car overall looks like it is in reasonable condition but actually the floor edges have been repaired with B 7 Qs finest sticky stuff then dummied over with under seal. It is actually quite a good cover up ! and actually had even me fooled until I tried to scrape it off.
    So the restoration of this one went to back of the bus.
    Project for 2020 and the last imp I will be restoring ( in the world ever ! )
ID:	119 Click image for larger version
ID:	120 Click image for larger version
ID:	121 Click image for larger version
ID:	122 Click image for larger version
      Every car has a unique personality, this one is no different.
      We already have an original MK 1 August 1963 car we use for shows and events and that is Mildred Regestration 1444PF which we became custodians of after taking over from Mike Andrews.
      So at least we have a extremely factiry car to compare against for Doris !
ID:	131Click image for larger version
ID:	127Click image for larger version
ID:	129Click image for larger version
ID:	130Click image for larger version
        Time to look at the engine that ahs been lying for so long
        Not good news, not sure if I will get away with the scoring but head bolt bosses on the block one needs attention.
        Clean up then check rings and bores. Looks like I will need to be hunting another curly engine though as this one might only be fit for a rebuild
          Decided to look at the engine that was on Doris
          Broken top of liners in that one although the crank looks OK even although -10.
          So thats the spare engines checked and no good
          Looks like I will need to go buy an engine now damn damn damn
            Doris has seen the light
            After years of storage that is Doris emptied and torn down ready to trabnsport to the workshop
            Shocking how many parts are NOT on a Mk 1 imp compared to the Chamois model that we all love.
            No dash to speak of, no door cappings, no door cappings...... nout
              All the original parts have been kept and are actually in suprisingly good condition.
              I have the interior in attic at home, considering the age most of the issues are faded red vbinyl and stitching that has just rotted.
              Even the headlining is still intact but I have my hesitations on refitting it, I have 3 of these headlinings so I am messing with the idea of having a local trimmer try and clean and patch the original up.
              So stripped, bagged and tagged
              Somne of the repair areas, most expected,
                What did you think that was it
                  And there is more
                    Doris has now landed in the workshop
                    The workshop is pretty much "work in progress" like the car itself
                    Click image for larger version  Name:	20221108_124148.jpg Size:	195.0 KB ID:	20409
                    And of course the imp leaves a mess wherever it goes and needs swept up
                    Click image for larger version  Name:	20221108_130906.jpg Size:	188.0 KB ID:	20408
                    All settled in
                    Click image for larger version  Name:	20221108_155404.jpg Size:	121.8 KB ID:	20404
                    Click image for larger version  Name:	20221108_155644.jpg Size:	120.3 KB ID:	20403
                    Wondered why the lights on trailer failed, seems I must have bent the socket or it got fouled
                    Click image for larger version  Name:	20221108_161724.jpg Size:	120.3 KB ID:	20406
                    Click image for larger version  Name:	20221108_162724.jpg Size:	177.8 KB ID:	20407
                    Man why do companies just stuff wires in a hole and screw down on them breaking strands, cant have that can we
                    Plus seems I have sprung a leak
                    Click image for larger version  Name:	20221108_155803.jpg Size:	206.1 KB ID:	20405
                      #11
                      Primary survey now done after getting it on the jig. Not as bad as I thought, all the usual suspects
                      The passenger rear floor was as bad as though through and the usual sweeping the car off the floor
                      And onto the body when tilted
                        #12
                        And always more
                          #13
                          And more of the same born stuff
                          Very surprising but the front valance is nowehere near as bad as I though, certainly not worth a 1/2 valance or the full NOS front panel I have so thats 2 spare panels to sell on
                          Click image for larger version  Name:	20221117_152351.jpg Size:	140.4 KB ID:	20492
                          Click image for larger version  Name:	20221117_152032.jpg Size:	121.7 KB ID:	20493
                          Click image for larger version  Name:	20221117_152223.jpg Size:	171.3 KB ID:	20494
                            #14
                            The inner wheel tub outer repair sections also arrived from ESP so tried them against the factory front wings.
                            A few small tweaks and at least the inner arch section will seat perfectly, a lot better than the one I tried a few years back, we really are starting to get much better quality panel availability now
ID:	20496 Click image for larger version
ID:	20498 Click image for larger version
ID:	20500 Click image for larger version
ID:	20502 Click image for larger version
ID:	20504 Click image for larger version
                              Hey John,
                              No need to ask what you will be doing over the festive period then? ,
                              Think you are going to be kept very busy with the cutting disc, grinder and welder for a while.
                              Good luck with Doris.
