Fuel filler hose
    replied
    Running original ones still , copy ones are too stiff and last nano seconds
    Leave a comment:
    replied
    Oli
    Could be, found out rubber not really rubber anymore, add fuel and it rotas like heck
    Leave a comment:
  • OliDP72
    replied
    The one I purchased was actually from Malcolm. Was a few years ago now - maybe a duff batch?
    Leave a comment:
    replied
    Where did you get it from Oli ? I got my last one from Bob and albeit a bit big and more rigid , the last few have been fine.All made in UK I think
    Leave a comment:
  • OliDP72
    replied
    The newer ones don't seem to last very long though. I went back to a good used original one after the new one cracked very badly after not very long.
    Leave a comment:
  • High_dan
    replied
    Just ordered one from Malcolm £25 and £5 for the overflow hose
    Leave a comment:
    replied
    Mike
    Yip 2" or there abouts and a 45 deg bend all that is needed. Did not find any that cheap though
    Leave a comment:
    replied
    https://www.txautosport.co.uk/produc...CABEgIHu_D_BwE would these work John? 51 mm 45 deg. Not had a standard filler on my imp for 20 odd years and never replaced one for anyone on a standard car.
    Leave a comment:
  • High_dan
    replied
    Thanks John, will ask Malcolm.
    Leave a comment:
    replied
    Dan
    My bad, I claimed Bobs last one for DDG
    Did Bob give a lead time for more as I think they are all made in the UK. I am not sure they are actually made for the Imp exclusively as I had to cut a fair chunk off the end to make it fit.
    Malcolm has them listed and also slightly cheaper than Bob
    You can buy the filler hose size off the shelf, but most start more expensive 51mm with 45 deg bend £20 plus
    Sorry to say but Malc would be your best bet
    Leave a comment:
  • High_dan
    started a topic Fuel filler hose
    Fuel filler hose
    Anyone know a supplier for the hose from the filler to the tank ? Mine is cracked. Club spares don’t have any.
