As per title..
I'm starting this thread and asking for advice here because I don't want to deal with dozens of peoples facebook advice when they have no experience. This keeps it simple and concise.
My Imp is a mk1. From what I know, most imps in NZ are mk1/mk2 with the high pivots. So I will make do with what I have.
Its currently running quite low (not Ash Cull low, but low enough) and I am happy with it. Here's a pic with the Datsun engine installed and one standard size Hannah installed
I have now installed the goldwing engine/subaru Leone 5speed box and added about 20-25 kgs (I will be borrowing some corner weight scales to confirm this in the future). It possibly sits a bit lower in the back now. Can barely spot it though...
Anyway. I want to sort some issues out. I lowered the front back in 2018 by creating some front monte carlos springs (read:'Makita one ways'). These measure up at 9.5" long. Here they are next to standard mk1 springs..
I then lowered my bottom spring perch by machining up a new seat and welding it to the bottom of the shock. Easily done if you're a careful accurate welder.
So now the spring perch sits lower. and there are no collets to fall out...
The bottom of the spring is about 50mm from the centre line of the shock mount bolt..
Understandably my shock length is too long to retain the springs when the imp is on the hoist so I added the standard spec straps..
Now this setup has worked fine and my wof (mot) man has had no issues with it. I have measured the camber at around 1 to 1.5 degrees, at a static height with no one inside but an almost full tank of fuel. The rear springs are less a half coil and seem well suited to the weight. I do intend to raise it 15mm at the back with a spacer due to the extra weight the rear now has.
The imp rides beautifully and handles really well imo. I have no other imp experience to judge it against other than the stock stand mk3 Hannah had in the UK but I'm very happy with how it rides and handles. Its not raced. Its just a fast road car.
I would prefer less front camber , as per what Mike Dent suggests. But I have not yet set out to adjust it because of the following......
Here in NZ our modified cars have to go through a certification process when you do things such as fitting a more powerful/different engine etc etc. My car is already certified for the Datsun engine, fitted waaaaaay back in 1990 or something. But I'll have to re-cert it for the new engine. I dont think the retaining straps are going to please the certification engineer and for non- certified cars they are not allowed anyway. Here is a bit from NZTA technical information sheet which states..
'replacement springs are self-retaining in their seats at full extension, without the use of non-standard devices such as wire-ties, straps, or external spring locators'
So I have to change my front shock absorbers to have no hassles when it comes to the certification and I would like to maintain a similar ride height.
These are my questions..
My springs are effectively Monte carlos with a 1" shorter free length. I have been offered some as new Gaz coilovers for 150 squid - the ones specified for lowered imps. From the pics I have seen on the Gaz website (which I must say is quite lacking in information...) it looks like with the collars wound right down the spring will sit around 20-25mm higher than my own setup. With the collars so low I then wonder if the spring will remain captive at full droop? If not then I will have to set the car even higher because I cant use straps. Otherwise I will have to get shorter springs.
Does anyone here have experience with Gaz shocks/monte combos?
Are the Gaz 'lowered/short' shocks the same length as the Spax lowered/shorter units?
If I go up an extra 1" in height I expect my resting camber will be close to zero, if not a positive figure? I can adjust that out once I have confirmed my ride height etc (again - taking mikes advice on how to go about this before de-cambering)
Are the extra low monte springs just less one more coil or are they set at a more compressed state so giving the same rate as standard montes ?
I like the rating my current springs have. I will measure them next time they are out but I figure they are around 200-210 ib/in if the stock ones were 195. I'm not really keen on going much stiffer.
Btw - as part of my engineering apprenticeship I spent 6 months in the blacksmith shop and I helped set many coils and leaf springs via the furnace and larger press etc. Very interesting (hot dirty) work. I have a decent enough bit of knowledge on springs but I'm here because you cant beat experience, of what I have on Imps is little.
I have owned both Spax and Gaz shocks for my Viva HB I had here in NZ and my UK based Mazda rx3. My only issue with the Gaz ones were corrosion from UK road salt. We don't use salt in NZ so not an issue. I am not sure who builds the best shocks. I have seen one video on youtube showing a Gaz unit being assembled and I was none to impressed when I saw they just use little plastic air bags to allow for the oil displacement from the shaft insertion on compression. I dont know if they have any extra gas filling to help stop cavitation? As I said earlier - the website is devoid of info on such things. Spax is not much better in this regards but at least they are gas filled. I know nothing of protec but they do look nice!
Lol @ wall of text. Hopefully I can get some advice. I will get the Gaz shocks offered anyway because I can at least try them out. I will have no problem selling them on if I decide to try out something else like protech etc.
Alex
Alex
