Bought Poly bushes for all suspension , just looking at fronts and pondering over modification it looks like l need to make . Think Pet "66" is a mark2 but built with mark1 bits (how do you tell the difference?) anyway attached sketch of sizes
Central pin will need shortening down to fit between movable clamp on rear of front suspension that has movement from approx 29-38 mm
,poly bushes together are 38mm so fit as they are , but internal size of poly bushes is 30.5mm but wishbone area they fit is only 28-29 wide
when clamped up fully will poly bushes collapse to 28-29mm ? clamping the central pin in place?do l shorten the pin to 36mm ?
Will bushes 30.5 dimension close down to the 28-29 dimension of wishbone when clamped?
Any advice greatly appreciated
