Keiths SInger Chammy
  • lm57krm@gmail.com
    • 7 April 2020
    • 116
    #136
    Hi John, yes using cellulose and a hvlp gun 2.0 for the undercoats and 1.5 for the top coat.
    I was just trying to paint a picture with the planets analogy the mist being so thick.
    Will give the laquer a try on a hidden area to see what it looks like but will mind your advice!
    thanks for all the tips really appreciate it.
    Cheers Keith
    • lm57krm@gmail.com
      • 7 April 2020
      • 116
      #137
      Jawel Paints - providing the trade with Automotive Paint and Supplies. Thousands of items in stock for next day delivery.
      this is the stuff I got. The write up seemed good.
        celly ? ear me Keith going completely period on that one Go thin and leave plenty flash time, otherwise the skin effect will leave the coats underneath soft for donkeys. Adding clear coat for UV seal will make it a bit worse if whats under is not flashed off fully.
        2K all the way baby done in morning, out in afternoon
          Keith
          See here
          single stage base coat, the small ripple/orange peel in the base coat as applied too thick and when I add clear it will stay there unless I am very lucky with the wet on wet flash times.
          Get you base coat the dogs before any clear coat
          Not fussed as this is just a tidy up of the van but your car will look cool.
          • lm57krm@gmail.com
            • 7 April 2020
            • 116
            #140
            Hmm, taken on board. John. So if I leave it to fully flash off then do clear later and possibly a bit of 1500 grit to key the surface once it hard?
            anyway I fixed up a tiny extractor but now Linda has hung up some washing! Click image for larger version
ID:	15291 Click image for larger version
            • lm57krm@gmail.com
              • 7 April 2020
              • 116
              #141
              Despite its size the extractor is working well to clear the fog. Full steam ahead.
                Great stuff Keith, the extraction will help loads.
                Looking good, but yes, make sure your base coat is as good as you can get it crap, ripple, peel, spot wise and good coverage before doing clear.
                If you change your mind on the clear coat I have plenty 2K here
                  Extraction not only helps the paint finish but your ability to be healthy enough to drive it once your finished too .
                  Great stuff seeing the paint going on Keith.
                  You will have it ready for Mondays meeting in Dunfermline at this rate..
                  • lm57krm@gmail.com
                    • 7 April 2020
                    • 116
                    #144
ID:	15313 first coat on, starting to look like a car again!
                      Thats looking good Keith, you lost 4 4 spoked off back wheel though
                        Spot on Keith, looking good all in the one colour and must be a great mojo boost for yourself seeing it painted now.
                        Doors, bonnet and engine cover this weekend then?
                        • lm57krm@gmail.com
                          • 7 April 2020
                          • 116
                          #147
                          Col, yes I don't have room to do doors bonnet etc with the car in the garage so need to make sure it's not going to rain as I'm sure water droplets on the new paint won't end well!
                            Keith,
                            I thought that would be the case seeing you only have half of your garage sealed up. Makes sense to check the weather so you can leave the car outdoors whilst you paint the doors, bonnet and engine cover etc.
                            Looks good for the rest of the week so the car can bake in the sun this weekend whilst your painting.
                            Keep us posted.
                            • lm57krm@gmail.com
                              • 7 April 2020
                              • 116
                              #149
                              So I painted the boot lid with 1k acrylic nail polish. Smells awful but it is quite shiny. Now undecided what to do. Will sleep on it! Click image for larger version
                                Keith if its looking good and plenty to cut back go for it. Will at least save any paint fade.
                                Must admit looks really nice that colour in the sun.
                                But take advantage of the current free "heating" for the booth
