Period Decamber Mods shim up stub axle
    Mike,
    I actually intedned to update this one but might keep it with the car. Thanks for the extra write up !
    The decamber worked well on standard springs which I think was the original idea as a slice and dice was cheaper than a spring and adjustable platforms.
    However the front end still sticks up a bit and stiill looks like a motorboard in the water, a look I dont like.
    In this case its high pivot.
    So I dropped the nose with shorter springs but of course the wheels now lean in too much, so looks like I will either replace the stub axles with later ones (if i have any good ones) or move the wahser to the opposite side to uncamber the de-camber effect.
    The springs are loose so some adjustable platforms are on the agenda, wont be this year, budget for car is completely blown
      Do the early and late stub axles have different camber angles on them? I thought it was only the steering arm part that was a different length and angle for the pivot height. I would move the washer (free to do) And you could try this https://www.ebay.co.uk/itm/Faulkener....c100005.m1851 cheaper than a pair of dampers or buy some dampers of me next year lol.
        Mike
        The helper springs would be an idea but compared to the cost of a set of dampers too much to throw away
        Will be new dampers so i can set the height better,
        Stub axle wise I *think* the stub axles have same offsets only the length of the pin was changed, grease nipples added. If there are any other changes I am not aware of them.
        The fixed length control arm was only difference I was aware of escluding actual wishbones and brackets
        But then again I might never have noticed as only attention I have paid is if it looks OK in the end
        John.
