poly bushes on front suspension
    Yes , still needs a bit of modification , need to machine it off to roughly the same angle as the mounting plate, bought it home and did a trial fit and noticed straight away my mistake . obviously the two short bolts are just holding it in position , just in case there's any confusion .
      Awaiting arrival of front shocks , any pictures of how they are assembled into top mount would be good , Will there be two rubber bushes with metal plates either side?
      does one go above mounting plate before it is slotted into H section , working on the principle "if in doubt ASK"
      Thanks Bob
        • 4854
        #33
        Based on standard assembly Mike would need to advise any changes on the pro-techs moose549
        First drawing here shows sequence but misses out the actual shock mount. Description is accurate
Name:	front assembly1.jpg
        Second one here is better and shows the actual top mount plate for the shock, you can assemble the lot off car and then bolt that plate in, two studs in inner arch area and the other two bolts are obscured by the fuel tank
Name:	front assembly2.jpg
          Yeah that's what l needed. Will see what l get and it should be obvious , looks like two steel washers and one rubber bush above then.
          THANKS
            • 4854
            #35
            Bob, 3 washers and two bushes bottom bush has washer pointing up calamped with lower cup of the top spring mount. Top side lower washer cupped up should have a ring edge to centre it on the top of the suspension mount, cup the bush and the top washer cup down to clamp.
            I will have plenty here Bob if you need any, might have some good bushed also, just need to make sure that the protechs dont come with their own bushes.
            IF you need them just ask
              #36
              The dampers are on the way. It is really simple to fit. I will do you some photo's and possibly a video of me fitting them tomorrow.
                You two DIAMONDS !!!
                Yes John will message you of my needs.
                Thanks Mike ,will have rest of funds sent to you shortly also washer jets etc
                Ebay is helping out with funds Mike , got springs , ebay also helping there .ha ha!!!!
                  Nice new toys.
                  Thanks Mike Click image for larger version
                    Assembled new toys
                      • 4854
                      #40
                      Lovely shiny Friday Bob. Will be great to see how it sits
                        "Nice" things on a Friday evening. :)
                          • 4854
                          #42
                          Guiness ?
                            Guiness ?
                            I did mean those lovely springs and shocks but since you suggested it I got a Guinness.
                            Their a bit of sexy car stuff and i was trying to be polite. ;)
