Keiths SInger Chammy
    Keith
    I tried loads of coatings, that one for the cost and the fact that it comes thick like finishing filler made the decision for me. Seam sealer is OK but it never actually gets into tight seams, anything inide always works its way out.
    Thinned down to 20% it flows great for spray with 1.6-1.8 setup or if the car is tilted it can be poured into joints and will weep in to any crevice really to seal it. Example, once floor is done tilt at about 30 degrees so whatever you pour under the box channel at the sill will head to the floor seam to middle sill and it will run along and weep down, you should be able to see it weeping out at floor so put something down. Once some wet has been pourd in, drop some thicker stuff in there, I use a syringe and tube , like a wet seam sealer, gravity and the still wet layer does the rest.
    Once that is hard then car on its side and seal other edge of sill/floor area, floor/wheel tub, rear crossmeber area, chassis legs.
    You get the idea. Very versatile stuff and as it binds to a well keyed not greasy surface, will also act as a part adhesive, I have left two bits of metal I have used as mixing sticks on bench a few times and found it a serious effort (well vise and hanner/chisel) to split them apart.
    • lm57krm@gmail.com
      • 7 April 2020
      • 116
      #62
      John, thanks for this. I think I said previously your posts are remarkably educational. I have ordered up and will give it a go. Syringes and tubes sound good.
        Keith, coating are nothing new, I just apply them a bit differently from most !
        • lm57krm@gmail.com
          • 7 April 2020
          • 116
          #64
ID:	8841 getting on with the passenger rear quarter now.made the corner myself. It's close enough.
          • lm57krm@gmail.com
            • 7 April 2020
            • 116
            #65
            Rear quarter. WIP
            • lm57krm@gmail.com
              • 7 April 2020
              • 116
              #66
              Got the Radford panel to fit. Click image for larger version
                The "red devils" are a challenge sometimes Keith, as i said in my other post, this is best use I found for them, chop up and use bits
                Click image for larger version  Name:	20200608_135748.jpg Views:	0 Size:	52.6 KB ID:	8887
                I amanaged to get onto the filling earlier keith, will post pictures later but wish I had just changed whole arch now as trying to match the profile of a fctory panel onto the repleacement bits is proving to be a bit of a chore.
                I hate the white stuff.....
                • lm57krm@gmail.com
                  • 7 April 2020
                  • 116
                  #68
                  Holes filled with epm121
                  ​worked a treat, thanks John. Click image for larger version
                    No worries Keith, I am waiting to see what else you can come up wioth it use wise
                    • lm57krm@gmail.com
                      • 7 April 2020
                      • 116
                      #70
                      Made a start at getting years of thick grease off the underside. Very messy, I'm not enjoying this part. Click image for larger version
                        it is absolutely a horrid job for sure. Dont evnvy you that one Keith !
                        • lm57krm@gmail.com
                          • 7 April 2020
                          • 116
                          #72
                          Finally got through layers of grease to uncover rust. Phew. Click image for larger version
                            They look in good nick Keith
                            You should just knock out the bearings gives good opeprtunity to clean those up and re-pack if they are good.
                            • lm57krm@gmail.com
                              • 7 April 2020
                              • 116
                              #74
                              Yes, I will do that. I think the driver's side needs replaced anyway as it's not as smooth.
                                They do look good, painted with some magic stuff and they should be good for years to come.
