MK1 Singer Chamois
This is a sticky topic.
    It does indeed Dave, I still need to make one for the hazard lamp switch now that I found one and also te choke control which I have relocated to below the shelf (I did not have one on the floor
    Looks a great match Dave, top work as usual
      Having had these 3 years ive finally fitted the rear wood cappings that match the door ones .
      Bit tricky on this because as you can see they are shorter than standard due to the cage so as with most stuff on here its modified
ID:	10321Click image for larger version
        Pre winter antifreeze check.
        Cocked up the Singers slightly as its on 52% and has been since i changed its stat ages ago .
        Vuskys engines still warm from loads of running around so that can wait til later
          Nice job on the mdding Dave, just playing with getting some deptha nd lacquer on some capping myself, looks like it is meant to be like that
            Thats always my plan , glad it worked
              Good idea on the coolant check, reminds me to give Mildred a once over.
                More Singer shenanigans .
                Fitted a flat fiberglass boot base as i did in the Vusky ,
                Then replaced both supply wires from the ignition switch to switched fuse box using that special Radox 155 cable - and of course using the correct colour of white .
                Then after some checks its first fire up in a month , started first time after a bit of cranking over
ID:	10785Click image for larger version
ID:	10786Click image for larger version
ID:	10787Click image for larger version
                This however is a mess --- although it works fine
                  Dave, nout you can do on the wires unles you yank it all out. Those multi pole connectors I used on DDG work very well.
                  The tank ribs are a pain, remember thos Nitendo Wii fit mats ? those cut up nice as well to fill the ribs. Great for bottom of rear pockets as well.
                  Nice work young man
                    A use for some offcuts of that red fiberglass .
                    Rear pocket bases
ID:	10875Click image for larger version
                      Always though it was a shame they never lined the pockets Dave, especially in the chammy,
                      One of the things I always thought about was making a pocket "insert" to pull out to clean, cleaning down there was always a pain
                        it is , nout in mine ATM
                          Wrenched the boot carpet out of a scrap Focus and after a bit of butchery part of its now in the Singer to replace the rubber mat which has perished somewhat .
                          Well i say carpet but its not really , its more like 2mm thick felt .
                          Long term plan is to edge it with something , what , how and when is anyones guess .
                          Got enough left to do the Vuskys one day
                            Dave, old door seal crimped on to carpet edge ? or could it even go over the bump and crimp the felt on tank edge ?
                              Trial CNC machined alternator bracket fits a treat
ID:	14066Click image for larger version
ID:	14068Click image for larger version
ID:	14070Click image for larger version
                                Dave,
                                They look properly well made, sets of the engine bay a treat.
                                Nice.
