Dave, you have lost the belt gaurd I think ?
MK1 Singer Chamois
This is a sticky topic.
Might come up with something at some point , the new set up is great , very easy to adjust and the alt wont drop or move even if the main bolt comes loose , might have a deeper but standard size pulley at work i could " try "Originally posted by John A. Ross View PostYes the catcher Dave
Repaired the rear roof panel , headining was coming off and the hardboard was warped quite bad .
I have some hardboard but went with a mega thin sheet of fiberglass which I covered in some 2mm closed cell foam to get the correct thickness .
Reused the original clips and headlining part.
Came out all right - no more warping one hopes
