    Next is 1/2nd synchro hub but first it needs building back up and you need the tool as described in the manual to put the centre spring clip in Click image for larger version  Name:	IMG_20210419_115134118.jpg Views:	0 Size:	3.18 MB ID:	14490
      Put the spring clip in the middle and gentle push the tapered end through the ring gradually expanding it in to the groove position the ends of the spring in one of the smaller quadrants Click image for larger version
        Now place the centre on the table put the ring over the top and push through , you may need a small screwdriver just to push the ends of the clip in the groove .
        don't worry if it springs out one of mine went straight in the other was a pig Click image for larger version
ID:	14494 Click image for larger version
          Iam going to take a break now back later ?
            #125
            Gary
            Wow, that was a marathon, many thanks for taking that time. Brill
              Next you put back the 3 sliding keys unfortunately I forgot to take any pics but it's described well in the manual just make sure the bottom of the clips are not resting on the inside of the key I had to grind a little of mine if there are any marks on the OD of the clips stone smooth you can't get them new so you have to use what you've gotClick image for larger version  Name:	IMG_20210501_093108311.jpg Views:	0 Size:	3.40 MB ID:	14508
                They should now push through with a click as the middle ring drops into the outer groove then push back with the same pressure .
                Be careful with 1/2 sliding sleeve as it only has one outer groove and if you're not careful it will push straight through and the clip will spring out ? everybodys must have done it at sometime don't forget to oil as you go, not to much Click image for larger version  Name:	VID_20210419_121500450_exported_767~2.jpg Views:	0 Size:	265.8 KB ID:	14510 Click image for larger version  Name:	IMG_20210422_141745233.jpg Views:	0 Size:	2.46 MB ID:	14511
                  Slide on the shaft make sure the outer groove on the sliding sleeve faces away from the pinion head as per drawing in the manual at the same time fit the selector shaft Click image for larger version  Name:	IMG_20210422_144908407.jpg Views:	0 Size:	3.05 MB ID:	14515 Click image for larger version  Name:	IMG_20210501_093055734.jpg Views:	0 Size:	2.41 MB ID:	14514
                    The selector shaft lugs should measure.250" the groove in the synchro hub should measure .270" so check for wear
                      When you fit the bulk rings make sure the 3slots locates over the 3 keys
                        Next fit 2nd gear bush and gear plus a little oil Click image for larger version
ID:	14520 the one with two pin holes in
                          Fit the 2 pins and 2nd selective washer Click image for larger version
                            Next 3rd gear bush the one with 2small slots and 3/16 slot at the other end line the slots up before you put the gear on Click image for larger version
                              Click image for larger version  Name:	image_5378.jpg Views:	3 Size:	3.26 MB ID:	14526 Put the gear on plus a little oil,fit the Woodruff key.
                                Now fit the 3/4th synchro hub with the selector fork make sure you locate the 3slots on the bulk ring over the keys Click image for larger version
